I had a tire break the bead this winter and got it fixed. I was wondering if I should store it sitting on the tires like I normally do or jack it up off the floor? I don't really want to have the tire go flat and ruin it eventually. I have a Troy Bilt Storm 2410 and was wondering if I stored it with the tires off the ground, should I put blocks under the axles, belly pan, or a combination? If I put a 4x4 under the belly pan, the tires come about 3/4" off the ground. I just don't want to cause any kind of damage by using a 4x4 where it is. It basically is running from tire to tire right under the axle.
