1973 Charger 340 CID no factory AC. I would like to add aftermarket AC using the Sanden compressor.
There are a couple of brackets on the market to mount that compressor. No problem running 2 belts on big blocks, but only one belt on small blocks.
Question: Anyone figure out a way to mount a Sanden compressor on a small block and run two belts.(I do have correct pulleys and alternator that would normally come on AC cars as well).
It appears that the compressor crashes with the thermostat housing using any of the brackets available on the market.
I'll fabricate my own brackets to move the compressor toward driver side if I have to but I insist on running two belts.
