iagree
Originally Posted by Stanton
Rockers are worth more than the heads !!!
iagree
T&D Machine catalog shows part # 8240 fitting Edelbrock RPM heads, being the closest to stock might be the best bet. The notes say for use with OEM stands and “Bolt-on assembly, no machine work required” and “May require minor clearancing” and may require taller/fabricated valve cover. Definitely would call them up before dropping that kind of coin twocents
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
