7T means 1977 Trenton plant. It doesn't mean Truck. Late model blocks tend to have inconsistent cylinder wall thickness. If you're going to build a performance engine you'll need to have the block sonic checked. A fair number of those blocks will fail a sonic test so don't assume that it is good until it is verified.
