On the Monaco above, the tach is not. On the fender tag, so it was added to the car.
Would the tach really be shown on the fender tag? I would think possibly on the build sheet, some interior option?
I believe it is on the fender tag at least on a 71 A body. Can't recall the code at the moment. Also I believe it's on there because of the hole in the firewall for the trigger wire. Others may say different ???? [/quote]
If Im remembering right. the tach is called out my my tag as T7
