I think it's mainly to help cure some of the issues with the some of the guys that like to screw around forever. I'm sure there will be some learning curve and a few bumps in the road that will be need to be address before it's ironed out and a good working system. If racers would just focus on making a pass instead of all the different games and what not, such things wouldn't be needed. The next thing they need to work on is getting cars into the lanes. A class shouldn't need to be called 100 times for the cars to come to the lanes. Call them 2-3 times and if you're not in the lanes by x amount of time after being called, you miss your run.
At most big money events the door cars are called to the lanes first. The dragster guys are known to be late getting back from getting their hair permed
