Improper pre-lube of lifter/cam Bad batch of lifters Maybe double check the diameter of the lifters as my father in law had a set years ago where 1 was smaller diameter than the rest. Maybe these 16 are larger than spec and weren't turning. Way too much valve spring pressure
