Might be easier to list what is correct.
It's not a Coronet R/T so no matter how much of one they put on this car it's not correct anyway, so stop worrying about it.
I mean just under the hood, the exhaust is incorrect, the valve covers are in correct, the electronic ignition is incorrect, the ballast resistor is incorrect, the radiator is incorrect, the fan shroud is incorrect, the battery is incorrect, the battery hold downs are incorrect, the trans cooler is incorrect and that's just what I can see.
If I was looking at it I would judge it based on what it is and whether I thought it was worth what they were asking, but I would never judge it based on what it isn't and never will be,
