Narrowed Dana 60 rearend.Has 4.10 gear ratio.Very clean inside.Has factory pinion snubber..Spring perch Center hole to center hole is 38 inches.Over all housing length 46.5inches.Large bolt axles.Comes with Multi bolt pattern NEW drums.Has what appears to be A body backing plates that are used.$1000 firm.Call only 603 209 1678.Pick up only.I WILL NOT SHIP THIS..
