Originally Posted by John_Kunkel
Originally Posted by madscientist
Just like drip tabs and the idiotic bolt with a hole in it, the slinger does NOTHING. It was a bean counters answer to other issues.
And what would those "issues" be? Since one job of a bean counter is to keep track of expenses, why install a ten-cent part in millions of applications that eventually adds up to tens of thousands of dollars?
They wanted to keep oil leaks down. It was a cheap, easy way to do it. The bolt and the drip tab do nothing. Oil weeping out of a bolt hole doesn’t put enough oil on the timing set to matter.
Again, warranty money.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
