Originally Posted by MoparJason0O0
Wanting to get some advice or examples of anyone changing to Lower gears in 1/8 mile.
Info:
1/8 mile only footbrake bracket car
Current 4.11 gears
1.76 Powerglide
32x14s
Shift at 6700 and cross right around 6700-6800
6.0s at 112mph in 1/8
Any issues going to a 5.00 gear ratio? Thoughts?
If I read the above correctly, you're shifting at 6700 and crossing the line at about the same.
Going from a 4:11 to a 5:00 is going to have you crossing ~7.5- 8k (rough guess). Can the motor handle that?
