Originally Posted by slantzilla
Which number would you use for a Wallace calculator guess at Hp, Weight, and ET?
Sheet is for a 500 inch Brodix headed RB. Hp is 710, Corrected is 790.
Is that enough steam to push a 3000# A body to mid/low 9s?
Thanks! wave
Depends on the weather conditions that you race in. Here in the northwest we race near standard conditions a fair amount of the time so corrected power is okay to use. If you're racing in heat or at altitude you should stick with actual power since that is what you'll be making most of the time.
