Originally Posted by TJP
Originally Posted by MoreParts
Originally Posted by BDW
That looks interesting, but it only does 1 size?
Seems like it would be a better design if it had different size inserts?
Wouldn't work on the steering coupler?
Nope. It'll just do standard size roll pins.
not trying to be a D-ck but Roll pins come in many sizes and lengths. I agree with the different size insert idea. up beer
i also agree with the different size inserts idea.
also, when using a standard flat face punch instead of a roll pin punch, the flat nose punch used will be just a whisker smaller than the roll pin, causing the punch to insert itself into the pin, which results in untold aggravation while trying to remove said pin. however, learning "new words" and expressing them in the process, can be greatly "educational" to young minds if they are within earshot. biggrin
a couple different size roll pin punch sets are well worth the money spent, even if a guy only uses a few different ones over his lifetime.
beer
