Originally Posted by chrisf
i have used ATF with good results for 25 years does not leave it greasy. just use a tiny bit on a cloth
I assume you're talking about Mercon/Dextron? I'd be concerned about what the additives in more modern ATFs like ATF+4 or ZF fluid might do.
No longer taking $h!t from anyone!
