Originally Posted by dvw
Start by checking the toe. If the wheel is off the toe has changed. Usually a toe change is caused by a camber change. It doesn't take much. Look at the front tires. Are they layed in? Check with a digital level. If the wheel has only moved 1/8 turn or so nothing has probably moved very far.
Doug
That's a good idea - never thought about using a digital level - just ordered one!
