If you wanted to use Jack stands behind the front wheels as extra security for the event that a ramp failed, you could position the ramps behind the front wheels and then back up onto them. Then the ramp does not block the pinch welds behind the front wheels allowing you to place a Jack stand on the driver and passenger sides.
Kodi
