I have assembled my first engine, 383CI, after brought back from the machine shop. The first 6 pistons went in, torque to spec engine still can turning by hand, but when the 7 and 8 pistons installed, it's can hardly turn over even though with 24" bar. Is this normal because the assembly is new or it should still can turn by hand. Thank you
