Cab, I bought the super pro pump. My motor is sealed up very well, other than this pesky deal at the sheet metal valley pan. The port I meant in the fuel pump block off plate is intended to leave a gauge, or hook up a gauge too. I will put the main line port in the top of the valve cover.
