Originally Posted by 6PakBee
If you really like the car and the price is right, I'd go for it. What's the worst that could happen? That you'd need to get another 383? Or sleeve the engine you have if it went south? I'm not even going to ask where someone got a 0.090 over piston set.
400 B engine pistons? Might even be a 400 block, so a casting number check would be in order.
July 19th should be "Drive Like Rockford Day". R.I.P. Jimmie.
