Does whatever EFI system you're using adjust timing to maintain idle speed? All modern stuff does it but I'm not sure about aftermarket EFI. When it drops into gear it should add timing to compensate for the additional load.
'18 Ford Raptor, random motorcycles, 1968 Plymouth Fury III - 11.37 @ 118
