Depending on the vehicle's use, energy consumption can be less than 14 kilowatt hours per 62 miles (100 kilometers)
You can believe that if you want. Care to buy a bridge?
I can believe that. I'm interpreting 14kwh per 62 miles as 14kw for one hour driving at 62 mph. 14Kw is about 20 hp so flat, level road with no wind....I can believe it.
None of their other claimed numbers pan out in the real world. Charge times, range estimates, carbon savings, etc.
For all you know they went 6.2 miles at 10mph on a dyno and extrapolated the rest.
