How do i index it?
You rotate the pinion adapter until the tooth range you're using is at the 6 o'clock position, as shown in the attached image.
Mods, can this image/info be added to the speedo pinion gear info in the tech archives, please?
OK, I found the info in the archives, but there's no mention of how to properly position the adapter, so maybe just an edit would help: http://www.moparts.org/Tech/Archive/auto/21.html
