So my new 340 decided to do the unthinkable...bent valve?? Thats my only guess.
Question #1: Will poor oiling to the top end contribute to a bent valve? I have oil to 6 of my 8 rockers(passenger side). Oil does make it to the other 2 but no where near as much. Very slight. What would cause this??
Question #2: If the cam bearing was improperly installed would I have
any oil at all to the right side? The left side lubes up just fine.
Question #3: Will bending a valve ruin the seat? Or can I just replace the valve if no damage was done to the piston/walls.
All other cylinders have 150 psi and all the rockers move as they should. I watched them to make sure the are all moving the same distance up and down.
Thanks for taking time to read my post and any info is greatly appreciated.
