they ar ok..just not good on longevity
as the cone wears it eats into the case and puts metal shving in the oil
most I have seen used have not had very good service on the oil change and the bearing are pitted up
but when in good working order they are just as good as a clutch one IMO
just wont last as long with out preventive maintanace and oil changes
look it over good so it not 700$ after the 300+ $ used
I have had one redone,its tight as a .....
well it chatters the tire on turns so its a grabin good lets say
runwhatyabrung
