Originally Posted by Jeff_383
Well, I may look out for a 3.55 third member then. It does drive well with the 3.91's. Just want a little more on the freeway for some longer trips. I also really like the new PTC 9.5.
You say "third member".
If you're planning on hooking this combo at the track with slicks, you're going to need to upgrade to something stouter than an 8 3/4.
'63 Dodge 330
11.19 @ 121 mph
Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
