Originally Posted by Sniper
It replaces the stock tailshaft housing with their own adapter then uses a coupler to hook the stock tailshaft to the GV box input.
They have a kit for the short tailshaft setup.
Right they have a short one but you use their transmission output shaft. Unless you cut the threads off? Picture looks like a different output.
That's the 4x4 trans kit
Quote
Uses 4×4 output shaft and housing.
https://www.gearvendors.com/product/automatic-3-speed-shorty/
This is the 2wd short tailhousing kit
https://www.gearvendors.com/product/automatic-3-speed-727-8-gas-tailhousing/
I know all that. My point is the transmission the poster has shown with the bolt on Yoke is not compatible with the GV as the output shaft has the threads on the end. The rest of the transmission is ok but you have to use a later non divorced transmission output shaft.
