primer is a big waste of time as is base clear. acrylic enamel with hardner or a good single stage is all you need.the more paint [primer] you use on your engine the sooner it will fall off in big chunks.most low gloss engines look like they were painted with spray cans.i will take the Roger Gibson look any day over the home brewed spray can look.
spray bombs work me me , i 'em , not sit around with the hood/off open sipping umbrella drinks
