Originally Posted by Cab_Burge
Your combination is very close to my old S/P car, similar weight, HP and tire size. Shifting it at 7000 RPM in the 1/4 mile that car ran 8.862 at 148.6 MPH, moving the shift RPM up to 7300 RPM the car went 8.866 at 150.4 MPH shruggy
That surprised the heck out of me, shifting it 300 RPM later out of 1st gear made the car pickup 2.+ MPH in the last 300 feet confused All the other times, 60Ft,330, 660 and 1000 Ft times and 1/8 mile MPH were identical shruggy
I did switch the rear tires later to a set of Goodyear 15x33x15 and that help hook the car up better over the Hoosiers and M/T boogie up work
My new car will have 17x34x16 slicks on it due to having a lot more HP2300+ and in a smaller lighter weight car hopefully making north of 2500 HP luck devil
What was your trap rpm in 1/4 mile? 8 inch or 9 inch converter and what tires were you using?
