Originally Posted by Rug_Trucker
Originally Posted by NITROUSN
From the FSM. Fuel Pressure: 18-24psi at idle, 28-36 at 2000 rpm with no load.
The FSM bible says 3lbs minimum on page 14-86. I'm not finding maximum pressure. This lift pump looks like a carb'd gasoline motor. It has a lever on the back side of the pump to prime the system.
Okay, 3-5psi off the lift pump found it on page 14-83.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
