66-67 hemi used the same fuel pump and pressure and they did not have a vapor separator or return line. So the choice of using a vapor separator is purely based on whether you think your set up will vapor lock. Having lower rated fuel pressure pump in a 383 motor would be MORE susceptible to vapor forming in the fuel pump and lines and they don't use one. Even on the HP motor.
