The filter is Fram's HPG1(10 micron Filter)
Is this considered to restrictive if placed between the tank and pump or should I just plumb this between the pump and carb and call it a day and not worry about any filter between the tank and pump. (I did put a new filter sock in the tank)
Put it between the pump and carb. Your pump will work better if it's after the pump.
