For comparison, here is the same curve from a different car that I tune. This car is roughly the same power to weight ratio but it leaves a lot harder. The RPM curve is very different. I'm suspecting the torque converter but I don't really know, it could be something else. This car has a driveshaft sensor on it. The green line on the screen is the driveshaft speed.
