A close examination of the damage to the box will show impacts from the rear of the crank 5-6 inches above the floor turned both sideways as well as 180 degrees. Also note the two dents on the side of the box nearest the crank. They are pretty high and look to be created by the counterweights on a fairly steep angle.
That little guy was dancing in there.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
