Originally Posted by rickraw
Moisture still can get in the system and dot 5 doesn’t absorb it, then the moisture can cause corrosion.I just flush every few yrs.
I've just restored my Demon and used Dot 5 for the first time. Everything works great and would definitely recommend it.
If it's a sealed system, how would moisture get into it?
Not being a wise guy, I promise.....If it can get in, I won't take a chance and flush it every few years also.
Thank you!
