Originally Posted by Chargerfan68
I say yes with tubes. If the slick spins on wheel, it could /will pull tube and rip off air stem valve. That’s why I run screws.
When I run dragradials, the tires move atleast a couple inches. You can mark them to check. Imagine slicks at the track on sticky surface.
iagree If you're running tubes, I'd be using screws.
CHIP
'06 GMC 2500HD LBZ Duramax
