Originally Posted by Blown 68 R/T
Tex have you ever checked to see if the gasket is hanging over in the chambers in certain area's?
I did a quick visual and seemed ok .Never noticed any sign of burn on gaskets when i swapped the heads between the 3 different motors .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm
Power by Tex's Automotive
