I recall, years ago seeing a new cast alternative to the leaking/weeping factory housing. I've had this Jeep, 1994 since 1997...Swapped thermostats out a few times over the 240k. The housing is once again seeping coolant....so, figured I'd ask.
I did order a new steel one....maybe it's gonna last longer than the stock one...I do recall using coolant sealant only the last time I sealed it up....
thanks for the feedback!
-dc SOUTHERNPLAINSMOPAARFEST.COM 2018 Jeep Trackhawk 1994 Jeep Grand Cherokee, 5.2 AWD-Daily grinder since 1997 1971 Barracuda, 414ci, 6bbl Fitech, 727 1970 Barracuda Convertible, 472 Ray Barton Hemi, 727
