Originally Posted by dodgepaul
Originally Posted by Cab_Burge
That is one of the early Mega blocks hence the cast in M emblem in the middle of the block on both sides up twocents
Thank you. And know I'm more confused than when I started. Mega good? Mega bad? World good world bad? Haha
They can be good or bad. You won't know until you take it all apart and have a pro check it out. Magnaflux, pressure check, sonic check, etc.
