Zero experience with filled blocks. I can say, from experience, that water comes out of both sides of the drained block. No way would I trust draining only one side. I run softened water with water pump lube during the race season, and softened water and coolant, mixed 50-50. I then check for -25 -30 fahrenheit. This is an iron R1 block.
