Spray moisture-displacing fogger "stuff" in the plug holes and rotate the crank to expose the valve seats while you're doing it. While it's the off season, rotate the crank 90* every month to ensure the same seats & valves aren't exposed the entire time. Plug or tape shut any exposed holes (carb, exhaust) to keep the elements from getting in.
I have first-hand experience w/ what happens when you DON'T do this; it required pulling the heads to get the valves & seats touched up that had rusted during the down time... totally self-inflicted.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
