I prefer crimped hose fittings. My last two cars were done with all Brown & Miller Racing Solutions (BMRS)
https://bmrs.net/ As for reusable fittings and hose I use Fragola.
Brown & Miller crimped for me too, expensive but I think the quality justifies the extra expense.
How much does it cost to get setup to do the crimped hose fittings?
Fragola does a portable unit with hand pump for ~$3400. Others do the same machine with an electric pump. Don't know what they run. Then you need the tooling. And the hose. And the fittings.
A normal person would need to be making hoses for people to justify that investment.
Drive out to PRI next month with your checkbook. That would be the place to get hooked up.
