I have rebuilt many of my own hinges with the Dorman pin and bushing kits.
A good piece of advice is to spend a few dollars and get a drill bit long enough to go through both sides of the hinges when you drill them for the bushings. It is pretty much impossible to line the top and bottom holes up by drilling one side then the other. If the holes aren't lined up the hinge bushings will be short lived.
