1st time out, very pleased, but there’s more in it!
#3090241
10/29/22 04:01 PM
10/29/22 04:01 PM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
I’ve owned my Demon since I was 15 years old (54 now) Bracket raced it quite a bit back in the 80’s to the early 90’s with a low compression 360 and a .484 purple shaft cam to consistent 12.30’s - 12.40’s The car became an afterthought when family needed to come first....in a stable part of my life with too much time, enough money, the energy level is lower and body pains become more prevalent. I’ve spent the last 5 years doing a full rotisserie restoration and building it the way I’ve wanted to for years! During the build my painter had a massive heart attack and almost died…..he thankfully recovered. Then back in June I suffered a stroke which I’m 90% recovered from…..it’s been one heck of a journey. I’ve definitely learned technology has come a long way since the days of the Purple Shaft Cams and B&M Super Holeshot Converter! Car is all steel with US Cartool frame connectors, a fiberglass six pack scoop (hood isn’t painted yet) stock glass/interior. Front end is pretty much stock w/QA-1 90/10 shocks - front runner tires. Rear end is 8 3/4, S/S springs moved in to frame rails, 4.30:1 gear, Mopar long shocks for S/S Springs and M/T 275/60-15 Drag radials. Engine is a .30 over 360 with a Rod Bloomer 4.125 crank/kit to equal 420 cubic inches. Compression is near 10.5:1 eddy heads gasket matched and some bowl blending/Hughes roller rockers. Bullet hydraulic roller cam .573 lift around 250 @50 duration. Eddy Super Victor intake with a Holley 750HP that flows 820. Trans is a well built 904 with 2.76 low gear set, T/A manual valve body and a PTC converter that flash stalls right about 4000 rpm. MSD 6AL ignition and an aeromotive A2000 fuel pump. Went to the track Sunday, it was about 65 degrees, slight tail wind, perfect conditions! Needless to say I was pleasantly surprised!!! I have many people to thank that have helped…. There’s many here that I've asked questions, gotten advice, and have read a lot to build this car as it sits today. For that, I am very grateful. Enough of my boring story....time for the good stuff! Sunday morning I woke up at 4am….like a kid on Christmas morning….I just grabbed coffee and went to the garage. Hooked up the car about 8am, got to the track about 9. Waited til they opened the lanes at 10:30 - warmed up the drivetrain with a few laps around the pits and jumped in line. I was hoping I didn’t forget how to do all this….did a decent burnout, staged and decided to make an easy pass. Had a good launch from about 1200 rpm, shifted early and lifted - ran a 12.35! Ok Wow! That was easy. Next pass…..it’s game on. Did a good burnout, launched at 1500…..and the pics will tell the rest of the story. The 4:30 is a bit steep, the engine wasn’t pulling as it should have through the lights, I let off just before the 1st mph light when the engine was singing up around 6500. Going to look into a 4:10, maybe 3:91 - looking for suggestions??? Thanks for listening and definitely thanks for all the help gang!!
Wally.
Entire Thread
wkroncke17
10/29/22 08:01 PM
Re: 1st time out, very pleased, but there’s more in it!
markz528
10/29/22 08:18 PM
fast68plymouth
10/29/22 08:55 PM
Wirenut
10/29/22 09:26 PM
ZIPPY
10/29/22 09:30 PM
justinp61
10/29/22 10:50 PM
slantzilla
10/30/22 12:53 AM
wkroncke17
10/30/22 01:27 AM
Brad_Haak
10/30/22 02:11 AM
Diplomat360
10/30/22 02:15 AM
wkroncke17
10/30/22 03:19 AM
crackedback
10/30/22 06:01 AM
J_BODY
10/30/22 12:05 PM
justinp61
10/30/22 01:50 PM
n20mstr
10/30/22 03:24 PM
68hemiss
10/31/22 07:25 PM
HardcoreB
11/01/22 12:30 PM
gregsdart
11/01/22 01:09 PM
wkroncke17
11/02/22 01:14 AM
Cab_Burge
10/30/22 02:47 AM
wkroncke17
10/30/22 03:13 AM
