Re: It's a turd, what to look for?
[Re: JAKE68]
#3089051
10/25/22 09:07 AM
10/25/22 09:07 AM
Posts: 5,166 CT
GTX MATT
CT
So in a nutshell changes are
Ported factory intake instead of the RPM Manifolds with Super Turbos instead of headers and Flowmasters Custom cam instead of XE274 800 AVS instead of 850 HP Holley
Assuming you don’t have a fuel supply issue, if the cam is right and you’re determined to make it work with the manifolds i’d try the RPM again with the 850. Maybe your ported intake doesn’t work that well. If it picks up alot try the AVS to see if it likes it or not compared to the Holley.
I also think Super Turbos aren’t a great choice, but not sure if it matters with the manifolds or not. Thats where I’d go after the intake if you’re determined to make it work.
Now I need to pin those needles, got to feel that heat Hear my motor screamin while I'm tearin up the street
Entire Thread
parksr5
10/17/22 12:19 AM
polyspheric
10/17/22 12:28 AM
Blusmbl
10/17/22 12:30 AM
parksr5
10/17/22 12:55 AM
GomangoCuda
10/17/22 02:39 AM
Locomotion
10/17/22 12:45 AM
parksr5
10/17/22 01:04 AM
parksr5
10/17/22 01:07 AM
CMcAllister
10/17/22 01:24 AM
parksr5
10/17/22 01:33 AM
parksr5
10/17/22 01:39 AM
Cab_Burge
10/17/22 01:51 AM
madscientist
10/17/22 01:52 AM
parksr5
10/17/22 02:46 AM
slantzilla
10/17/22 03:01 AM
parksr5
10/17/22 03:16 AM
CSK
10/17/22 03:28 AM
lewtot184
10/17/22 11:18 AM
Blusmbl
10/17/22 11:46 AM
BSB67
10/21/22 02:15 AM
lewtot184
10/21/22 12:54 PM
Cab_Burge
10/21/22 05:51 PM
fast68plymouth
10/23/22 07:26 PM
parksr5
10/24/22 12:56 AM
fast68plymouth
10/24/22 02:08 PM
GTX MATT
10/24/22 02:53 PM
parksr5
10/24/22 08:30 PM
krautrock
10/24/22 08:47 PM
parksr5
10/24/22 09:11 PM
lewtot184
10/24/22 08:48 PM
parksr5
10/24/22 09:14 PM
LA360
10/24/22 10:50 PM
JAKE68
10/25/22 12:23 PM
GTX MATT
10/25/22 01:07 PM
moparx
10/25/22 06:19 PM
JohnRR
10/26/22 03:22 PM
BSB67
10/27/22 02:57 AM
John Brown
10/27/22 04:23 AM
JohnRR
10/26/22 03:14 PM
roadrunner2
10/26/22 04:15 PM
lewtot184
10/27/22 11:40 AM
lewtot184
10/25/22 12:13 PM
an8sec70cuda
10/25/22 12:21 PM
Cab_Burge
10/26/22 01:46 AM
lewtot184
10/26/22 02:01 PM
roadrunner2
10/26/22 02:38 PM
fast68plymouth
10/24/22 09:06 PM
BSB67
10/26/22 12:20 AM
madscientist
10/17/22 01:56 PM
fast68plymouth
10/17/22 02:06 PM
CMcAllister
10/17/22 02:17 PM
krautrock
10/17/22 02:03 PM
340Cuda
10/17/22 04:21 PM
Torquemonster440
10/17/22 03:25 PM
parksr5
10/17/22 04:17 PM
fast68plymouth
10/17/22 04:36 PM
dvw
10/17/22 05:06 PM
CMcAllister
10/17/22 05:47 PM
HotRodDave
10/17/22 05:06 PM
