You are correct on fitting size, I've been to EVERY local part store in my area and nobody carries 3/16". I've noticed on a lot of occassions they use the next size under hose, to go on the fitting . So I'm thinking 5/32" hose to go on the 3/16" fitting ???? Thanks, Kevin
