Those holes will disturb the airflow into the primary introducing a side shear effecting distribution, no???? It would have been interesting to see an AF ratio before and after mod. Including cylinder to cylinder on a dyno. Carter and the OEM had a lot of different strategies with the AFB. For some of the Chevy versions the anti perc tube was hidden and not exposed above the top.
