All,
Got the shifter mounted and have wires hooked up for the neutral safety switch.
My question is….has anyone used this? Where do we run the wire to on the relay?
I have the diagram from the instructions but want to be 100% sure I’m going to the right place so it works.
I don’t have the factory one hooked up or the wires run, so I’d like to use this one.
Hopefully it’s been used with good results.
Thanks all!
Wally.
