I did verify the timing. I use an ATI balance with a Stanke timing pointer. I will be going back on the dyno in a month and try to creep up on the timing and see if the numbers drop. I also am trying to find a solid roller lifter that will work. NO ONE besides Jesel ($3500) makes one.
