Originally Posted by racerx
Any ideal if there will be short deck wedge version available?
That one looks pretty short already. The deck is cut down to the water passage bosses at the front of the block.
He said hemi block, so do these new blocks serve as a base for the hemi and wedge blocksshruggy?
All the casting problems over the various iterations of blocks has come from trying to produce a wedge and hemi block from the same casting. I would geuss Hemi only. Also looks like that block is -.300 deck height.
