I just installed Holley Sniper EFI, new aluminum intake, and headers on my 440 that has 750 miles on it. Engine fired right up, but when it gets to max temp 185-190, it starts blowing blue smoke from the exhaust. Any thoughts on what would cause this? There also appears to be oil dripping at the header collector flange. When I replaced the headers, I installed a fresh set of plugs and noticed that they had oil on them. I checked the PCV valve and it's good. I'm planning to do a compression check on all of the cylinders next but thought I'd check here the mean time.
